Milling MDF
7/20/15
John McGinnis Member
I am currently working on a project that requires lots of milling on the face of a sheet of 5x10 MDF. I cannot post a picture of the product as I am under a confidentiality agreement but I will explain as best as I can.
Each 5x10 panel is first cut into 4 quadrants with a 3/8" compression bit. Then I am using a 1/4" downshear bit to mill concentric circles in the face of each panel. The circles start in the center and grow outward. Each pass is a diffreent depth- usually stepping up or down by either 1/8" or a 1/16". The end result is profile that looks like a lot of little stair cases. Each 5x10 panel takes about 4hrs to mill- just to give you an idea of extensive the milling is.
So far the panels are great in every way except one- the MDF is very fuzzy wherever it is cut. I have been using brand new tooling from Vortex and I have tried using a couple different brands of MDF. As I said earlier, the bit is a 1/4" downshear and I am running conventional cuts at 18000 rpm and 300 in/min.
Any advice on how to reduce the fuzziness would be appreciated. I am a pretty new at this- just got my first CNC at the end of last year.
7/20/15       #2: Milling MDF ...
KenW
Try Plum Creek brand MDF....that what we use and have great luck...
7/20/15       #3: Milling MDF ...
I second that. It is the board, not the tooling. Plum Creek finishes nice without fuzzing. You can also get a super refined or similar grade MDF from most manufacturers. Shop grade MDF is not intended to be used that way.
7/20/15       #4: Milling MDF ...
I've actually been using mostly Plum Creek. I will give the super refined a try.
7/20/15       #5: Milling MDF ...
On second thought, it might be tooling. ? You are taking too small a chip load(0.008) building up heat, and dulling tools too quickly. 240 minutes of cutting is a lot. Try dropping the RPM's or increasing the feed speed. Depending on Depth of cut, you can choose either. Can you use a bigger diameter tool for the "stairs"? Try for about a 0.015" chip load.
7/24/15       #6: Milling MDF ...
Sir CAMalot Member
Make sure it's not lightweight MDF, Trupan, etc. It has a lot less binder (which is why it's lighter) to keep the fuzz in check.
To add to what Mike said, make sure your gcode is using G02 or G03, otherwise your CAM software may be creating a series of steps to simulate an arc but your machine will never get to the full feed rate, hence, dull tools. Seems like if you were running the feed rate you think you are (300 IPM) it should be done in less than 4 hours.
7/24/15       #7: Milling MDF ...
Thank you all. I will check the code to make sure I'm using G02 or G03. I think the material is a big part of the issue. Luckily, I am at AWFS and was able to connect with the folks at Plum Creek who are going to send me a sample board of their Super Refined. It seems pretty dense so I'm hoping this will solve a large part of the problem.
