Best bit for routed holes?
9/1/15
Bob
Does anyone have any suggestions on the best type of router bit for this application?
These are holes that are approx. 9/16" diameter, and I tried running them with a 1/2" downcut spiral. Not a good idea! Chips are being pushed to the bottom of the holes and creating a lot of heat.
I thought I might try a compression spiral, but I'm concerned with it pulling up veneer on the face. Also thought about using 1/4" diameter bit??
View higher quality, full size image (585 X 551)
9/1/15       #2: Best bit for routed holes? ...
Todd71
Have you considered "Brad point" drill?
I try to use them when I need flat bottom holes. Its a lot faster and less machine wear than circular interpolating a bunch of holes. Good luck
View higher quality, full size image (1000 X 1000)
Brad Point Drill
9/2/15       #3: Best bit for routed holes? ...
james mcgrew Member
I did a perforated detail with Aluminum Laminate , ( I presume you are doing this on a cnc) Mine was done on sintra and had heat and compaction as well.
I ran a first pass with a .25 DS bit partially into material. then switched to a .25 US bit for the cut thru, time consuming yes but the work looked great !
9/2/15       #4: Best bit for routed holes? ...
jerry Member
Why not mirror the image and cut from the back with an up spiral bit
9/2/15       #5: Best bit for routed holes? ...
Snaglpuss
Worse comes to worse- drill with a smaller sized bit and mill the hole with a 1/4" bit.
9/2/15       #6: Best bit for routed holes? ...
1/4 Spiral would be a great choice. Then, you can rout the hole size needed.
9/2/15       #7: Best bit for routed holes? ...
Dan
I would not use a compression bit, they are not designed for plunge cuts. I think a 1/4" up shear and cut from the back side.
9/2/15       #8: Best bit for routed holes? ...
Phill
I'd try a 1/4" mortise bit.
9/2/15       #9: Best bit for routed holes? ...
I like 3/8 up cut bits better than 1/4, less chatter. I would also experiment with a shallow climb cut, then full cut, to see if you get a better finish.
9/3/15       #10: Best bit for routed holes? ...
Rich  Member
I would also drill a smaller size hole in center then come back and rout to final size with 1/4" router.
9/7/15       #11: Best bit for routed holes? ...
Gary B.
If you don't have alot of holes, I could see trying to get by with the tools you have on hand. If you have to buy any tools, why not just buy the right sized drill bit and be done? It will be a lot faster to machine.
