Aggregate
1/22/16
Matt Member
I'm trying to have a aggregate built with 4 output spindles running in line to run up to 1/2" diameter cutters. We had one built a few years back and it was NOT a success. The only way we could make straight, consistent width slots was to make 4 or 5 passes. At that point I'm faster just to do it one slot at a time. Also, we ran the aggregate on multiple machines, some much beefier than ours so I don't feel the machine is the problem.
1/22/16       #2: Aggregate ...
Matt,
I am not really sure what you are asking. Is there a better brand of aggregate other than the unnamed one you are referring to? If you are willing to spend money on a custom aggregate, you must be doing a lot of something you didn't specify. If it were me, I might want to talk to a custom machine manufacturer, present your application and see if they have a solution that will give you better, faster cuts. If a new machine is not in the budget, then I can only say that of the three aggregates that I have hundreds of hours on, the Benz has been more reliable than the Atemag, both made in Germany. Custom machine brands that come to mind made in the U.S. are Northwood, Onsrud, and maybe Komo.
