Handheld Contour Edgebander
2/2/16
Luke Vickery Member
Website: http://www.calwoodinc.com
Does anybody have any suggestions on a handheld contour edgebander? I need something that will apply 3mm PVC x 1-5/8" to countertop edges. Suggestions are greatly appreciated. (i.e. make, model, pros, cons)
2/2/16       #2: Handheld Contour Edgebander ...
Brian
Website: http://clancywoodworking.com
i bought a viretex last year and used it for some veneer work and it works great. takes a little practice though. their glue works great, its clear so it doesn't leave a line per say. i looked at the import one but decided that I'd rather buy this machine. they also threw in an end cut off and hand trimmer which pushed it over the edge for me. its excellent quality.
Brian
2/4/16       #3: Handheld Contour Edgebander ...
We recently bought a Festool unit. We only do edge and but it is a quality unit. It uses pucks for glue so it is easy to keep clean and it heats up fast. We were able to get a Festool rep in to demo it and we bought it after the demo. I looked for years and the Festool made me the most comfortable.
Good luck.
2/5/16       #4: Handheld Contour Edgebander ...
Derrek
Website: http://closetdr.com
I have a Virutex for about 10 years, just replaced with the Festool. The Festool is 27 times better than the virutex. Better quality, cleaner to operate, easier to use and better glue application. Got mine from Richie at Everready Hardware.
2/5/16       #5: Handheld Contour Edgebander ...
Pdub
Have you guys been applying wood edgebanding with the Festool? Read somewhere the top/ bottom trimmers are tearing out with wood?
2/5/16       #6: Handheld Contour Edgebander ...
Derrek
The trimmers are not on the bander. There are multiple options for hand held trimmers from a razor blade.to a dedicated router with round over bits
