Laminate with steel
2/24/16
Hi All
Need to cut 500 sheets of laminated material that has a thin sheet of steel under the face.
Any else dealt with this?
Any ideas?
2/25/16       #2: Laminate with steel ...
james mcgrew Member
Steel or Aluminum manufacturer should have recommendations?
2/25/16       #3: Laminate with steel ...
Stu Member
There are insert bits or PCD that would probably be a big help to you. Amana has a line specifically for ACM that might be worth a look too.
2/25/16       #4: Laminate with steel ...
daveguru
Be very careful with sparks if it is steel & not aluminium.......
There is a formica magnetic whiteboard laminate we have used often-difficult stuff to machine, we do a lot of it with hand-routers to avoid problems
2/25/16       #5: Laminate with steel ...
daveguru, yeah that's the stuff
