machining inside miter corners after using ball cutters
4/7/16
anton stayduhar
Hi, if I'm using a ball cutter to rout the inner edges of single piece, mdf panel doors, what's the easiest way of mimicking clean cut corners, i.e. removing the radiussed concave corners.
I do not have a door module. Does the scenario require tedious 3d placing of placing of curved lines in each corner, followed by pencil machining? What about the material immediately to the right and left of each corner?
4/10/16       #2: machining inside miter corners afte ...
Mark
I suppose it depends on your software, what do you use?
With AlphaCam for example, and other softwares I am sure, there is a profiling routine built in where toolpaths for a ball mill are automatically offset by the software according to a chosen profile. Maybe that is what you do already.
Say I have just routed a 1/4 inch step and bead around the inside edge of a door profile with a 3/4 inch diameter profiling bead tool like a vortex 7955 insert. I just draw a 1/2 inch square box in each corner I need to sharpen and apply a profiling operation mimicking the bead to the inside of the box with a 1/16 ball mill. I have all of this built into constrained templates so programming a door takes only a minute or two. Each corner takes about 12 seconds to sharpen up on the machine.
If you are doing the inner profiles with a ball mill the same technique could apply.
4/11/16       #3: machining inside miter corners afte ...
anton Member
Hello Mark, and thank you for responding.
I do in fact use AlphaCAM, version 14.
Can you tell me where I find this profiling routine you mention. I'll look for your response here, but please PM copy me. This ability is long, long overdue. In the interim, I'll look around. I imagine its under machining, somewhere. The program is an endless, mostly undocumented, English maze of tricks.
