glass inserts for slab doors
8/28/16
harold Morantz
We do mostly slab doors and are getting more requests for glass inserts and it takes alot of work to cut them out on the table saw and use mulimaster to finish inside cut square. these doors are not large and i was wondering if a small CNC router could cut these out. I have seen some for 2-3 grand with software that will work on up to 48" sizes. Anyone think this is a good idea and which machine would be the best for the job? thx, Harold
8/31/16       #2: glass inserts for slab doors ...
Generally against small CNC's, but it will work for this.
You're going to need a tool changer.
Make the cut out and back cut with a 3/8 bit and then a final pass with a 1/8 bit.
Find a CAM software that will automatically overcut the corners so you can fit square corner glass. I use SheetCAM.
Dead easy.
