Biesse Rover 37 issue with Quote
11/23/16
Chris Member
I have a 2004 Biesse Rover 37 flat table. It has a NC1000 controller.
Today I was cutting a few repetitive sheets, on the third sheet about half way through the machine stopped in mid cut. I went to the screen to see what happened and the quote window was gone. I figured it was a fluke and restarted the whole machine. The quote window appeared and the machine was fuctioning through the homing program, but when I went to change the jig thickness the quote window seemed like it was working but then disappeared again. What could be causing this? Could it be a communication issue with something?
Thank you for all your help.
12/6/16       #2: Biesse Rover 37 issue with Quote ...
Mark T.
The more likely candidate is the software has become corrupt requiring it to be reinstalled.
Mark T.
