vac lift repair
1/23/17
Gary
I have a Tawi vac lift for moving sheet stock onto my cnc. The pump/blower has locked up. I called Tawi and they will evaluate it for a fee and then send it out to be repaired. I would like to send it out myself instead of going through Tawi. Any ideas on where to send it? I didn't ask but I assume Tawi won't tell me.
1/23/17       #2: vac lift repair ...
cabinetmaker
Look on Anver Lifts I have had a lot of success getting replacement parts from them
If it's the pump you can check e-bay most of those are elmo regen. vac pumps
Are you sure it's not the belt ? If it's the bearings, should be pretty cheap or is it the motor ?
1/23/17       #3: vac lift repair ...
Gary
Not the belt or the bearings. This is the third time it has locked up. Not sure why. We take it apart and can't find a problem other than very close tolerances between the blades and the housing, put it together and it works fine for a while. We did try bearings but no help. I think it's time for someone who knows what they are doing to take a look.
