Tech support
5/31/17
Jim
Omnitech cnc router owners. Having some problems with tech support split between Giben and Anderson. Wanting to know if your are having the same problems.
6/1/17       #2: Tech support ...
Mike A
i have found similar issues. found it best to call my local independent tech. what part of the country are you in?
6/1/17       #3: Tech support ...
Maurice Phelps Member
Here is the defining line between the two companies.
Giben handles all Syntec controller Omni and Giben machine.
Anderson handles Fanuc controller machines.
Ran into the same problem a couple of months ago, Spoke with Tech support and Anderson and this is how they split the responsibilities.
6/1/17       #4: Tech support ...
Leland Thomasset  Member
I have an omni with fanuc so I have called the NC office with no issues thus far. With that said there is only one person I will deal with. TJ
