Aluminum
8/5/17
Akram Member
Website: http://www.americanvisioncabinets.com
Hi,
I have an Omnitech CNC Selexx router 10 Tool changer, we always cut ONLY wood, now I have a project need Aluminum to be cut almost 24 sheets
thickness is 3/8 there is a lots of cutting and 3/8 holes drilling.
is my machine capable to handle this project or will kill my spindle. I guess it is 10 HP
Thank you
8/5/17       #2: Aluminum ...
Anything is doable. Doesn't make it right.
You can do it with a proper bit. I found that 12K RPM is max, and no more than 0.125 depth of cut. Onsrud has a 1/4 bit for this.
I'd be more worried about the chips. You will still be finding them a year from now.
8/5/17       #3: Aluminum ...
Akram Member
Hi,
Thank you for your reply,
I cut a test part today suing 3/8 Onsrud but did not have air tip spraying air during cut, which defused the particle again to the part. it was not fun.
RPM 16000
Feed rate 64 IPM
Plunge 50 IPM
now, for such project who will be cutting it, only cabinet people will have such machine with vacuum, other places ( signs or welders will be having another type of cnc )
also under which category billing will be under, I mean charge per project or cnc hourly including drawing time??
I live in California
Thank you
8/5/17       #4: Aluminum ...
With aluminum you need to think about tip speed. google surface speed per minute.
I found that anything over 12K RPM with a 1/4 bit will cause re-welding of the chips. With a 3/8 bit the RPM will need to be lower.
8/6/17       #5: Aluminum ...
james e mcgrew Member
The hardness of the material will make a major difference 6061 is hard cuts better, numbers under 5k are more soft some for bending and forming,, these are gonna be prone to melt.. I have and do Alu work with my cnc for Specific jobs yet if i had 24 sheets of 3/8 i may look for a local company with a waterjet and outsource, we have one locally that cuts large gaskets for plants and they are more than willing to use the machine in downtime.
8/8/17       #6: Aluminum ...
I wouldn't do it without a misting coolant attachment. The misting attachment puts on a very fine atomized flow. The bit gets too hot and you will be welding aluminum to the bit without it. Personally, I wouldn't run a job that big in a woodworking shop. Your shop and dust collector will be a mess. You'll find aluminum cheap 3 years from now. I'd send the job to a water jet cutter and add a profit for handling. No fuss, no muss in your shop.
