Feedrate question pertaining to Holzher cnc
8/27/17
Ian Member
I have a question about the units used to set the feed rates in our machine It is a promaster 5225. I was under the impression that meters per minute were used as a standard, but after performing my own feed rate calculations for new bit (ex. - 1/4" comp spiral) the machine cuts so slow that it doesn't possibly seem right.I knocked the decimal back two places just to get parts finished and manually cut the feed, but I really need to know the proper multiplier.
8/28/17       #2: Feedrate question pertaining to Hol ...
Jerry Member
I think you are to use MM or CM
