tooling question
8/31/17
duster
What is the difference between a compression spiral and a mortice compression bit? Is it the length of the upcut? Are they interchangeable? Or do I need both types if I'm cutting through panels and doing dadoes?
8/31/17       #2: tooling question ...
Gary B.
Duster,
You're correct. The difference is in the length of the upcut. A normal compression will extract dust better, while the mortise compression allows you the ability to cut most dadoes without changing to a different tool.
9/12/17       #4: tooling question ...
Pdub Member
Our typical dados aren't that deep. So that doesn't apply to us. What it also does is let you cut 3/4" and 1/4" material without chipping using the same bit.
