Z axis control
9/13/17
Stewart Member
I've noticed when cutting on the cnc, that the most "inconsistent" axis is Z. I perceive that it is due to varying material thickness. We cut mostly plywood so the surface is not nearly as flat as the melamines/laminates. Before we output a job, I mic all the materials. I'll grab three sheets, mic them together, and divide by 3 to get a good average thickness per piece. If you are just through cutting, this isn't as important but if you are pocketing where you need to be within five thou, this can get really frustrating. It's almost like I need to be able to reference in real time off the top of the material rather than the surface of the spoilboard. Is there a way to do that?
9/13/17       #2: Z axis control ...
Yes, but it's expensive. Use a floating aggregate.
Or you could machine a larger flat spot before the pocket.
What are you cutting that you need a specific pocket depth? Post a pic.
