DNC Mode on SCM Pratix N
9/22/17
Jeff O'Dell  Member
Website: cncwoodworking.net
Does anyone know if an SCM Pratix N has a DNC function to feed a large surface machining program?
We're getting an out of memory message, with the standard program loading.
Thanks!
9/26/17       #2: DNC Mode on SCM Pratix N ...
Can you break up the program into sections?
I know that Sheetcam has a drip feed function. Never used it though.
9/26/17       #3: DNC Mode on SCM Pratix N ...
Jeff O'Dell  Member
Thanks. We thought about that, but wanted to run the entire program for part accuracy.
Turns out that while the SCM does not support a DNC Mode, they did make some adjustments in the control so that the machine was able to run the entire program.
9/26/17       #4: DNC Mode on SCM Pratix N ...
Glad to hear it worked out.
