Will Member
Our CNC was accidently stopped during a tool change. We have a Biesse rover J. Ive re homed it but it wont let me change the tool or even start up. Im getting an error code of PLC 9114 which says 'Load on occupied electrospindle from magazine onboard machine (1; in 596)'
Can somebody please help??
cheers,
Will
11/20/17       #2: CNC ...
The machine has likely lost it's way.
There should be a way to go into manual mode and step out of the spot you're in.
Once you are done, verify that all the tools are in the right place. There is nothing quite like using a short 1/8 but and getting a long 1/2 instead....
11/20/17       #3: CNC ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
You need to remove the tool from the spindle and move the spindle away from the tool changer. Then you need to place the tool in the tool changer. The machine technically "lost" which tool is in the spindle. It wants you to fix it by removing the tool.
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
johann@tmwsales.com
    • Machinery Associates
