Bit type
12/22/17
Cs
When using small diameter bits to square corners on MDF doors, what type of bit do you use? Downshear, upshear, straight?
12/23/17       #3: Bit type ...
Have used all of them. Doesn't make much difference.
12/26/17       #4: Bit type ...
Jared Emery
I use an Onsrud 1/16 diameter downshear with a cutting length of somewhere around .280 I believe, as we cut .250 pockets. A 1/32 inside corner doesn't need any further work and looks great.
