busellato 4002 hovering
3/14/18
Lorna
Website: http://abbeyowney.com
Our busellato machine moves into position but hovers above the boards, no warnings are showing
3/14/18       #2: busellato 4002 hovering ...
Check the program and all the manual overrides for feed rates. Could be something set to zero.
Been there, done that.....
5/4/18       #3: busellato 4002 hovering ...
Kevin Simmons
If feed-rate control is not the issue then you may want to check the BIOS settings of the PC. That generation of machine required either IRQ 9 or 10 to be reserved for legacy/ISA. Its easier to simply reserve both 9 and 10. This problem is usually triggered by a failing battery on the motherboard or a newly commissioned PC.
