square corner on biesse programming
6/4/18
sandman billy
when i loading the dxf file to a cut a sheet with sqare corner with a v bit. I have to go and check each box segment line date from scOFF to sc1 for each line in a rectangle that i want a square corner . I checked the square box in milling gemotry box also in setup but i still have to check the box and is there any other way . Also anybody i need code for a simple layer file for a material sheet 97/49/.75 Thank agin
6/6/18       #2: square corner on biesse programming ...
Dan
I don't know if you can get that SC done in a layer. Tried it some time ago, gave up & created a .bpp with variables for everything so that we can adjust & send to the worklist.
This can be done with the batch processing tool as well.
As for the simple layer for a panel
Put a 97*49 rectangle on:
TCHW0B8D7500
12/10/18       #3: square corner on biesse programming ...
Nathan
I have an inverted 45 degree cutter to create a finger pull . cuts 13mm deep and obviously under the material 13mm. With a standard 45 I just turn sc1 on etc and we square the corner out. Does anyone know how to do this with an inverted 45??
