Automatic tool checker
7/20/18
Steve Member
We have a HOLZHER lynx 7511. Does the automatic tool checker only check certain dismeters of tools? We are making doors and have a simple flat cutter for flat panel doors 1-3/4 dia. As soon as it picks up the tool we get a radius measure error.
7/20/18       #2: Automatic tool checker ...
ryan
The fool length gauge will only read tools that will completely fit on it. We have a 4" flycutter and have to just measure by hand.
7/20/18       #3: Automatic tool checker ...
On my touch probe, the machine reads the radius of the tool in the offset registry so it moves off probe center by the radius of the tool. Just have to make sure one of the three inserts on my fly cutter is over the probe. We just rotate by hand as it lowers in z and we are good to go. My machine in not a Holzher, but I would imagine the engineers there would have considered that(hopefully).
7/20/18       #4: Automatic tool checker ...
MICHAEL FRANCIS CASSELL
The tool touch off device has a maximum diameter of 20 mm and is used to measure tool length not diameter
7/25/18       #5: Automatic tool checker ...
Ian
We probably have the same one on our pro master, tell the MT manager that the tool is 19 mm, but only if you can contact the edge of the tool on the touch off device. It will be innacurate if not. Get a presetter for larger diameter, or see if the tool manufacturer can send you a dxf. Dorian has a presetter for around $3000, plus 500 for the HSK sleeve. Hsk 63 F is not listed in the selections of sleeves on almost all websites, but calling Dorian direct will get you where you need to be.
