3mm pilot drill, most appropriate type steel
8/15/18
Matt
Regarding a standard 1/8" (3mm) pilot hole drill bit, for 3/4" melamine/plywood.
Lately we've been having a LOT more break-offs than previous. We aren't sure of the cause but poor drill bit quality seems to be a contender.
The cut obviously is just a plunge cut through 3/4". Rotation is 9000rpm, feed speed (z-plunge speed) is 150in/min (3810mm/min). This historically has worked just fine for the past 8 years but suddenly we are breaking these 3mm bits several times per week.
Given these feed/rotation speeds cutting 3/4" melamine and plywood, is there a certain bit geometry and steel composition that I should get better life from?
We don't care if it chips the cut a little, pilot holes are never seen in the final product. We are just tired of changing these broken bits all the time.
8/15/18       #2: 3mm pilot drill, most appropriate t ...
Chris Harmon
Website: http://azurecabinets.com
I use a solid carbide 3mm drill bit from True 32. I never have broken a 3mm drill bit.
http://http://www.true32.com/3mm-Drill-Bits_c_71.html
8/15/18       #3: 3mm pilot drill, most appropriate t ...
Chris Harmon
I use the same speeds and feeds as you.
Rotation 9000rpm, plunge feed 3810mm/min.
8/15/18       #4: 3mm pilot drill, most appropriate t ...
Matt
Chris I suspect we're running the same CNC (CNT Motion).... if I'm not mistaken, I think you and I shared a table at IWF Atlanta a couple years ago at one of the evening meetings. If you're the guy I'm thinking about, we figured out we were running the same machine.
Either way, I will look into the carbide bits, I was under the suspicion that they would be even more brittle, but perhaps worth a shot.
8/15/18       #5: 3mm pilot drill, most appropriate t ...
Chris Harmon
Yes, I remember you. Are you going to IWF next week. If you are, I hope to see you.
8/15/18       #6: 3mm pilot drill, most appropriate t ...
jerry Member
Have you replaced the collet it may be the collet is worn out and there is to much runout or just a bad collet. Check the runout and see
8/16/18       #7: 3mm pilot drill, most appropriate t ...
Matt
We swapped the collet a while back but admittedly it's been a couple months.
Chris, I personally won't be there but the big dog will be, you'll probably bump into him.
8/16/18       #8: 3mm pilot drill, most appropriate t ...
CRIS
We use an 1/8 ballnose. onsrud upshear and get 5x the life of any drill we have ever tried. wither proper depth adjustment the through hole is very clean. try it it may work for you. S10000 F 400.
8/16/18       #9: 3mm pilot drill, most appropriate t ...
jerry Member
Are you doing peck drilling
8/17/18       #10: 3mm pilot drill, most appropriate t ...
CRIS
JERRY No through drill, one pass. I discovered the ballnose ont of necessity. Broke an 1/8 drill,only to discover we were out. so we tried the ballnose. I'm guessing we are getting app,130,000 to 150,000 holes per tool with clean bottom.
