Problem with Vectric Aspire -- drill toolpath converted to pocket toolpath
10/29/18
Pablo Cordal Member
Hi everyone,
I'm doing my first tests with Aspire 8.5. I'm trying to CNC (morbidelli) a guitar fretboard (I'm attaching here a print of the .crv3d file).
I find the following problem: when I go to Save toolpaths, the drill toolpath appear (in the .xxl file generated, a print also attached here) as G orders (pocket toolpaths) not as B orders (drills).
Any idea about what is or what am I doing wrong?
Thank you very much
View higher quality, full size image (1280 X 800)
10/29/18       #2: Problem with Vectric Aspire -- dril ...
Will Williamson
You would get more help here at the vectric forum http://forum.vectric.com/
10/31/18       #3: Problem with Vectric Aspire -- dril ...
Gerry
I agree with will the Vectric forum would be a better place to ask for help.
Are you sure you are using the correct Post P for your machine? If so I would contact Vectric support, they have been quick to respond and have always sorted out any problems I had with the Post P.
