Machining and finishing acrylic material
1/31/19
Derrek
I possibly have a project involving 3/8” acrylic doors. I have done this before but bought them from another company. We his project is pretty big and I am having trouble with the cost of buying them. I have a cnc and have talk d to Vortex about tooling. I have looked into finishing edges and most sources are cutting on a saw then doing a final trim with a router to smooth out then flame polishing with a torch. For those of you that have cut acrylic on a router, is the edge finish good enough off the cnc to go right to flame or does it still need a final trim before Yu can flame it
2/1/19       #2: Machining and finishing acrylic mat ...
Jerry Member
If you want to cut out the flame polishing you may want to check out the Onsrud 75-100 series of bits.
http://curvetube.com/75-130_3_8_PCD_Single_Flute_Polishing_Tool_For_Acrylics_Video
_by_LMT_Onsrud/5JOUnH2I8MY.video
2/1/19       #3: Machining and finishing acrylic mat ...
Snaglpuss
We use slow spiral "O" flute upspiral bits on acrylic.
Some examples in 1/2" Dia.-
Onsrud 52-650 or Southeast SOU742
In 1/4" Dia.-
Onsrud 52-624 or Southeast SOU-723
You might need to cut through in two down pecks esp. if using the 1/4" diameter bits on 3/8" thick acrylic.
In any case, after cutting through take a .015 clean up pass on the edge.
Also an arc in / arc out on the tool path won't hurt either.
We don't flame polish, we would finish them by sanding and buffing. this isn't a big deal or money investment if only doing a few. With a decent edge doesn't take too long.
If you have a choice cast acrylic cuts nicer than extruded but might be a little more money.
2/1/19       #4: Machining and finishing acrylic mat ...
Snaglpuss
I just looked up the price of the Onsrud PCD bit- $1500! Wow.
If you want to try flaming the edges better do some practicing on scrap. It's easy to screw up if you've never done it before.
Keep a fire extinguisher handy in case you light one up and can't wack out the flame.
2/2/19       #5: Machining and finishing acrylic mat ...
cabinetmaker
Definitely O flute. Slow the chip load down. Get a good edge. Sand lightly. Then flame
We flame 3form and lumicore all the time
10/10/21       #6: Machining and finishing acrylic mat ...
FORSUN CNC Member
Website: https://forsuncnc.com/
Are you considering buying a CNC router? CNC router machines can help sign makers to work with practically any material. You can use these sign engraving machines to carve signs in brass, wood, plastic, corrugated plastic, bronze, aluminum, styrene, rubber, acrylic, foam, and other materials.
    • Machinery Associates
    • Country Saw and Knife
