POLYLINE DIRECTION
2/27/19
Kevin Member
I have been using Biesse works for years. at a recent class the instructor informed me that in Auto Cad you can modify a polyline to dictate direction and the point at which the geometry begins. This would be useful in automatically importing geometry with layers to dictate start point and direction. Has anyone had success in modifying polylines in this manner?
2/28/19       #2: POLYLINE DIRECTION ...
Dan
Yes, for sure it works although it may be better practice to pick your start point and draw in the direction you want to travel.
Select, right click, polyline & reverse. You can use pedit to get there too. Remember to consider the left and right correction (made that mistake a few times).
BW picks up the direction, start point and whatever else you've got in the layer on automatic import.
3/1/19       #3: POLYLINE DIRECTION ...
Kevin Member
Thanks Dan. That gets me part of the way there. When I purposefully draw a shape starting and with direction in mind, the starting point changes if I modify the shape. The vertex function under pedit might have some use here but I cannot figure it out. I was hoping there would be a way to dictate the direction and starting point from Auto CAD. I have sought to do and end run by inserting a gap in a line or intersection. This would then allow me to dictate the starting point. I'll continue to look for was to accomplish this.
3/1/19       #4: POLYLINE DIRECTION ...
Daniel G Feron
Sorry Kevin, I'm not certain I get the
"the starting point changes if I modify the shape" part.
If by modify you mean add segments and join, yes that will cause problems.
It may be easier for you to draw your shape with lines and arcs as an underlay and then trace those with a polyline, layer it and delete the underlay once you're satisfied.
Post a pic if this isn't helping.
