Laguna CNC
3/22/19
Shane Member
Recently purchased an older Laguna Smartshop CNC with atc. I am having problems getting Mach 3 to read my Vcarve files and to correctly communicate what I can get it to read to the machine itself. It is like things are running backwards. Any help would be appreciated.
3/22/19       #2: Laguna CNC ...
This is most likely a post processor issue. You could contact Laguna with your machine model and serial number and ask for the appropriate PP file for V Carve.
If you are feeling confident you can have a look at the Post Processor editing guide in V Carve and I think you would just have to edit one or two lines of code to invert input dimensions. I can't be more specific as I haven't done much coding but PP files can be opened in Windows Text editor for editing. Make a copy to edit so you can always go back to the original. Test a simple file without a tool making an air cut to see if you are having success.
3/23/19       #3: Laguna CNC ...
Rob Young Member
Website: nutekmachinery.com
Shane- Contact V Carve and explain the problem to them. V Carve will write, edit, or provided a post processor if one already exists. V Carve may request a sample program. If so, contact Laguna for the sample program file.
3/25/19       #5: Laguna CNC ...
Shane Member
Thanks guys, I contacted Laguna and they wanted to charge me $180 an hour to look at it. I will be contacting Vcarve next.
3/25/19       #6: Laguna CNC ...
If you post a message on the V Carve forum with a sample file of a simple rectangle cut and circle cut along with the problem you are experiencing, I think one of the hotshots will have an answer very quickly.
Vectric will too I am sure. Be sure to explain which axis is backwards and any other anomalies you see.
