using car or motorcycle muffler for reducing vacuum pump noise
3/31/19
Julien
I was wondering if it's a good idea to use a car (or motorcycle) muffler for noise reduction of my busch claw vacuum pump. the pump is very noisy and cames without silencer / muffler. thanks for your inputs.
Julien
3/31/19       #2: using car or motorcycle muffler for ...
I'd be surprised if the air movement was the major noise contributor.
3/31/19       #3: using car or motorcycle muffler for ...
Can you plumb the exhaust outside?
3/31/19       #4: using car or motorcycle muffler for ...
BH Davis  Member
I've quieted smaller vacuum pumps with nothing more than a 4" diameter jar with a plastic lid. I mounted an input fitting on the lid face near the edge, then drilled an outlet hole on the face near the opposite edge. Worked great and I believe still in use 10+ years later.
Given this experience I'd say to give it a try. Just do a quick temporary connection to the pump exhaust to make the test. If it works then invest more time in making it more professionally done. Just make sure you have free air flow though the muffler.
4/1/19       #5: using car or motorcycle muffler for ...
Johann Huck Member
You can always purchase an inline muffler from places like McMaster Carr that are made for vacuum pumps. They are high flow and help reduce the noise. Just browse and choose the correct pipe size.
Johann Huck
Mufflers
4/1/19       #6: using car or motorcycle muffler for ...
Julien
Thanks guys! I'll try to find an inline muffler like those on McMaster Carr
4/23/19       #7: using car or motorcycle muffler for ...
Justin Hoover
I have a homemade vaccum I put on a chevy 2500 muffler works great!
