Chipload for Slot Cutter
5/7/19
I have a Whiteside 3075 2 flute slot cutter for making slatwall. Never have had to make this stuff before on a CNC. Anyway, its just for a short run. Does anyone recommend a chipload for this tool? I only have one tool to get through the job so your sweet spot for tool life will be appreciated.Thanks.
5/8/19       #2: Chipload for Slot Cutter ...
jerry Member
When I had to make slot wall I ran 2 files. The first was with a 1/4 inch upcut end mill just shy of full depth and then the slot wall cutter I also put a dust hose at the ends of the slot as there is a lot of dust shooting out.
I can't remember the feeds and speeds as it is on the shop computer.
