pocketing vs cutout
5/29/19
Ian
Curious what the general population thinks. I know what I would do, but I'm curious because of what I was told to do. I have to do internal cutout of shapes on a 5x5 sheet, 144 pieces per sheet stacked 10 deep, 1/8" thick per. Would you pocket it, profile cut with helical ramp down, or just profile cut around the internal edge? The leftover piece in the center will be roughly 1"+ . Just looking for opinions. Management has different ideas than I do.
5/29/19       #2: pocketing vs cutout ...
Ian
Program is Alphacam, machine is pod and rail. There will be a 1/2" mdf spoilboard, top and bottom.
5/29/19       #3: pocketing vs cutout ...
What diameter bit?
What finish do you want?
If the slugs will drop, I'd just do the cutout and let them drop. 45 degree ramp in for better speed and bit life.
If they are not going to drop, use a 1/2 bit and pocket them. 45 degree ramp in and pocket full depth. I've broken too many bits with a slug getting jammed sideways to leave the loose slug in the hole. Easier clean up too.
5/29/19       #4: pocketing vs cutout ...
Ian
most likely going to use a 3/4 chipbreaker. It won't drop through, I am going to use spoilboard on the bottom to help the cut quality. Depending on what finish is need, may use a rougher.
6/4/19       #6: pocketing vs cutout ...
cabinetmaker
much cheaper to pocket cut the waste vs chasing 1" and plugs even more so than letting them damage any cables in the chain
