Duct Design Service
7/18/19
Bob
I have new CNC coming and I need to redesign the duct work.
I have tons of pipe and I don't want to pretend i will buy stuff to get a free design.
Anyone have a suggestion of someone I could pay to do the design?
7/18/19       #2: Duct Design Service ...
Jared
Oneida Air will figure it out for you.
7/18/19       #3: Duct Design Service ...
Bob
Unfortunately they won't if it's not one of their dust handlers.
7/19/19       #4: Duct Design Service ...
Bob,
What kind of dust collector do you have? How many people do you have working? Or how many machines do you run at one time? What kind of pipe do you have?
7/20/19       #5: Duct Design Service ...
Bob
Scott,
We have 2.
Both are Nederman new S1000 and an S750.
The S750 will be for our dovetail machine and our edgebander.
The S1000 will be dedicated to our new CNC a Rover A.
This is the one I need the optimal performance on. It has auto unload. 2 large ports and 4 small ports
Both have main lines of about 50 to 75 ft.
7/23/19       #6: Duct Design Service ...
Dylan Bayliss  Member
Website: http://www.machineconsult.com
send me a pm, we are a biesse dealer and have the layout for the Rover A NBC
We can quote the qf pipe to S1000
Regards
db
8/2/19       #7: Duct Design Service ...
Bob,
Sorry I was on holidays.
If you have the one dust collector dedicated to just your CNC, there is not much design as you are limited to the maximum CFM of the dust collector.
You should use the same diameter pipe as the inlet on the dust collector. Pipe with smooth wall is best, but the spiral pipe will be ok. Limit the number of elbows, and any elbows you use, make sure they are of a bigger radius , use limited length of flex, and lastly the closer the dust collector is to the CNC the better it will be. Seal all your joints and one mistake people make sometimes is they use screws that are to long and they catch material and then the bigger pieces builds up in the pipe. If you are using the clamp together pipe that is not a concern.
Those are good dust collectors, you should have no problems.
8/2/19       #8: Duct Design Service ...
Bob
Thanks for the responses.
Dylan has me taken care of.
