Biesse CNC profile program
9/11/19
steve Fitzgerald Member
Website: http://www.flatpaxcuttosize.com.au
Hi does anyone know how to write a code on Biesse editor or does anyone know the method behind making a profile door pattern with an arched top. We can make an arched top profile but the arched top which automatically changes with different door widths is confusing us.
9/12/19       #2: Biesse CNC profile program ...
Jason Scott
You need to program your arch so the reference points are not fixed but variables.
If you use a 3 point arc for example you might put your start point as x=0, y=75
Your end point would be x=lpx y=75
Your midpoint would be x=lpx/2 y=0
I hole this helps. Email me if you need more help.
9/12/19       #3: Biesse CNC profile program ...
Dan
Further to Jason's post:
Every thing can be and is variable.
To draw your geometry, set up variables for stiles (SW=75), rails(RW=75), step to arch(Step=75), arch height(ARCHT=75) and so on. Your door height is lpx (800), width is lpy (500), however you want but that's the idea.
Line endpoints might look like:
From a start point
LPX-(RW+ARCHT)
LPY-SW
Then
LPX-(RW+ARCHT)
LPY-(SW+STEP)
ARC (three point)
CTR = lpx-rw, lpy/2
END = lpx-(rw+Archt), SW+Step
Line same x to SW and so on to close.
Change LPY to 300 and note the arc problem.
If you want to control the variables based on door width you would insert instructions at the beginning of your program.
An example for the above might be:
If LPY<=300 Then
step=10
SW=60
End If
The vb instruction can be as complex as you need it to be but does need to cover all the possibilities you may want to throw in. You can't leave holes in the logic.
You can test that:
Change lpy to 300 - it should work OK
Change LPY to 250 you should start to see a problem that requires another if then.
It's up to you how you correct the arc but I just threw it in with all the values to demonstrate.
9/17/19       #5: Biesse CNC profile program ...
Thanks so much Jason & Dan. Great information that really helped.
Dan you mention
"If you want to control the variables based on door width you would insert instructions at the beginning of your program.
If LPY<=300 Then
step=10
SW=60'
Where would you be able to put this in? Variables list, sub program ?
Ta Steve
9/18/19       #6: Biesse CNC profile program ...
Dan
Instructions go to the commands area.
Usually directly below the graphics.
From the menu you can select insert, instructions, condition 'if' or 'If else' to get the format or you can just write it in.
Make sure of where the cursor is in the program by selecting (left click) the line you want. Usually right at the start. You don't want it to end up in the middle of another command.
There is a section on vb script in the BW manual as well.
9/23/19       #7: Biesse CNC profile program ...
steve fitzgerald
Thanks heaps Dan. Getting info on these machines is hard to come by. Much appreciated.
