weeke programming
2/6/20
Chip Harron Member
Website: http://kitchencreationscc.com
I own a weeke vantage C.N.C. ( ten years old ) Since day one we have used KCD software for frameless panel production. We can do simple shape programming but quite honestly have no idea how to do anything else on this machine. I don't even know what he term g-code means but we do 2 million a year in cabinet sales. For example transfer shapes and or logos into a format that we could carve a sign or copy a map into a solid piece of wood. I know this machine is capable of so many more things. Is there anyone out there that could walk me through what is probably a simple process.
2/6/20       #2: weeke programming ...
You will need software other than you cabinet suite and a person to "program" what you want to cut. Nobody needs to learn G-code which is okay, Weeke doesn't read traditional G-code. The person will draw the necessary shapes and vectors for logos in the software you choose and output to the machine.
2/6/20       #3: weeke programming ...
steve
unfortunately no. weeke/homag use a proprietary 'g-code' and have their own programming language called woodwop. woodwop is great for those machines as there are no issues with post processors when using something other than 'normal' router bits.
however, the autocad/dxf import...sucks. no two ways about it, it's terrible. i've got 5 years on a homag, i can make this machine do nearly anything, and i've yet to do anything even half decent using the dxf import (without training and a VERY good understanding of autocad, which i do not have).
stiles machinery has classes if you're truly interested.
2/6/20       #4: weeke programming ...
Chip Harron Member
Thanks guys,
What I find interesting is that part of my KCD package has a function that will write the part number on a particular panel to identify it. We simply insert a dry erase marker into the tool holder. It doesn't work well but it basically copies a shape, which is all I'm trying to accomplish. I think what you are saying means that this is an internal function of my KCD prepackaged software. I may call them the see if I can import through them.
2/7/20       #5: weeke programming ...
Collin Parker  Member
Website: heritagewoodwright.com
u run homag, use vcarve pro for special stuff, exports to .mp4
2/7/20       #6: weeke programming ...
Alan F.
Your machine should have come with bpp
You should also be able to install a version of Woodwop in the office
See the link in the message from me in the thread below, you amy have to enable DXF import and then you can do file->import-DXF and it converts it or at a command line bpp will generate a mpr file you can use.
I don't have Woodwop any more so cant walk you through it, you can do most any shape or logo using the ply layer
http://www.woodweb.com/forum_fdse_files/cad/757364.html
2/7/20       #7: weeke programming ...
woodwop just as powerful as vcarve, but if ur machine 10yr old so is ur woodwop. if youre looking to stay homag then could learn it. if not a secondary program for $1000 like vcarve worth it.
2/10/20       #8: weeke programming ...
Alan F.
Chip,
Post a MPR file that KCD makes with the tool you are using and the number.
should be pretty simple to duplicate by making a block or importing a dxf and converting it to a ply file and inserting the ply file into a mpr file
A-
    • Machinery Associates
    • Country Saw and Knife
