SCM Pratix and V Carve Question
2/29/20
Jason Balm  Member
Website: waukeecabinetworks.com
We have a 2012 SCM Pratix with ATC running Xilog. I recently purchased Vcarve and am not seeing a specific post processor for this particular SCM machine.
Is anyone here running Vcarve on your Pratix? Did you need to modify, write, or otherwise acquire a post for your machine? Do one of the stock posts in Vcarve actually work even though they date back to 2008-2010?
I sent a note to customer service, but waiting for a response.
Thank you in advance for any assistance.
3/1/20       #2: SCM Pratix and V Carve Question ...
james e mcgrew  Member
I would create and run a simple file with z set up off table so you can avoid and spoil or material damage, worse that can happen is it will not work and give an error.. then post some of your code. There are 3 pp with as many machines (SCM) that I know using the software it should work. I cannot upload a zip or PP file yet can email if someone wants to help.
    • Charles G.G. Schmidt Co.
    • Country Saw and Knife
    • Template Services
