CNC collet dust extractor
3/12/20
I recall reading in the past that there are downsides to using the collets that help dust extraction.
Can anyone with experience comment on the good and the bad of these?
Dust Extractor Collet Nut
3/12/20       #2: CNC collet dust extractor ...
I hve one like this and an FSTool one.
This type will pick up small chunks of material which can jam in the unit, knock the balance off and burn the material you're cutting.
The FSTool is a lot more money but doesn't have the same issue.
For the record, they're both in my cabinet, not on the machine....
3/12/20       #3: CNC collet dust extractor ...
Mark
I've been using an NG Air Pro collet on my main cutting tool and on the mortise compression for many years now. Multiple materials from 1/2 inch MDF to 1 inch VC ply. Overall they work great and have really cut down on dust. I would not go back to bare bits.
Downsides:
1) After a long time dust can get packed around the lower bearing of the spindle. It has not affected spindle life that I can tell, but I did get some comments on the bearings from the repair shop when having the spindle rebuilt for tool changer issues unrelated to dust.
2) I have to be careful not to release small chips from a tightly nested sheet. Not a big issue for case parts but complex sheets like diewall ribs can require pocketing away any scrap less than say 4 square inches away, or making sure that a small piece like that is bridged to the waste.
3/12/20       #4: CNC collet dust extractor ...
Dave
These things can be NOISY!
[Main reason we stopped using ours]
3/13/20       #5: CNC collet dust extractor ...
cabinetmaker
We gave them up for a while over small parts jambing in between them and the materials. No we are pocketing the waste
They are great but will lift small parts, that’s been our experience
3/13/20       #6: CNC collet dust extractor ...
Derrek
I’ve tried a couple and it was just to noisy and we didn’t see a huge improvement over what we were already picking up
7/6/23       #7: CNC collet dust extractor ...
timothyferriss
Website: https://blossomwordgame.io/
Some collets can raise the tool's noise and vibration levels, which can be uncomfortable or annoying when used for an extended period of time.
    • Biesse America
    • SainSmart
      CNC and Engraving machines for Makers
    • Limtech Industries, Inc.
