Plyboo Linear Line Biesse Machining
4/28/20
Luke  Member
Website: https://www.segalebros.com/
We have a commercial project involving cutting and installation of several panels of Plyboo Linear Line collection LL7M.
After field measure, we know the walls and doorways are not at right angles. Also we have notching required to fit signage on the wall inside/flush with some Plyboo panels.
We want to cut the panels to fit on our Biesse CNC. I am looking for any advice on how best to cut this material. Do we need to run the tool at a slower speed and multiple vertical passes to avoid blowing out the vertical lines cut into the surface of the material? Material is expensive and limited, so we don't have a lot of opportunity for trials with this.
Looking for advice on this, if anyone has experience with cutting Plyboo Linear Line on a cnc. Thanks! Luke
Plyboo Linear Line Collection
4/28/20       #2: Plyboo Linear Line Biesse Machining ...
Tyler
Do you have the saw attachment for your cnc?
4/28/20       #3: Plyboo Linear Line Biesse Machining ...
Luke  Member
No we do not have a saw attachment. We have a panel saw but that will only cut right angles.
4/29/20       #5: Plyboo Linear Line Biesse Machining ...
If I was worried that a standard compression spiral wouldn't do it I would do a first cut about 0.010 oversize and maybe 0.250 deep with a hi helix down spiral bit. They typically have a lower chip load so it's be slower.
1/2 rather than 3/8
5/12/20       #6: Plyboo Linear Line Biesse Machining ...
Mike Grubbs Member
Slow your feed rate, use a down shear, and make 3 or four passes to an onion skin, listen to the tool when it makes the first pass and slow or speed up accordingly.
Whats your software?
