What Type Of CNC Machine Drills Multiple Holes?
5/16/20
Joe Wood  Member
Website: woodsshop.com/
I have 13 of these cedar posts, will probably 4x4, that need ten 3/16" holes drilled up them.
what type of CNC rig will drill these? Hopefully I can find someone in the San Diego area if I know what types of machines will cut these. It would save my poor elbow cutting all of them on the drill press!
5/16/20       #2: What Type Of CNC Machine Drills Mul ...
Joe,
Just about any cnc with a drill head will drill those holes, of course there are some smaller machines That may not have enough room on the z axis to drill a 4x4 post.
Most machines with a drill head would probably only be able to drill 2 or 3 at a time dependent on the spacing.
Even with only one drill bit you write a program and you could drill a post from both sides quickly.
5/18/20       #3: What Type Of CNC Machine Drills Mul ...
jerry Member
It would be faster to just make a jig and hand drill those holes.
5/18/20       #4: What Type Of CNC Machine Drills Mul ...
Joe Wood  Member
Yeah that'd what I'll do Jerry.
5/19/20       #5: What Type Of CNC Machine Drills Mul ...
Derrek
You will need a special tool to drill a hole 4” deep. Then you will also need a 4” stroke and a fair amount of clearance with a long tool. I would build jig to place in drill press and bust them out.
5/29/20       #6: What Type Of CNC Machine Drills Mul ...
Peter Matos
Almost any flatbed CNC router would do this. I would build a simple jig to hold the parts in position, program the pattern and peck drill them to clear the chips. As long as your machine has adequate Z axis height should be no problem. We have over 12" so it would be easy and much faster and more precise than hand drilling even with a jig. YMMV
5/31/20       #7: What Type Of CNC Machine Drills Mul ...
Ian
Maybe a pnuematic line boring machine
Pneumatic Line Boring Machine
    • Machinery Associates
