Vises
6/24/20
Good afternoon.
I'm looking for ideas on holding solid wood on a pod and rail.
Any and all pics/videos/ideas welcomed.
Thanks in advance.
6/26/20       #2: Vises ...
Ian
The way we do it most of the time is screwing a closed grain board to the bottom of it, just make sure you have enough material height if you need to undercut. If its flat and you won't see the holes on the underside, that should be ok too. We also use pneumatic vises that mount to the rail via vacuum.
6/26/20       #3: Vises ...
Thanks Ian.
Any pics of the pneumatic vises?
6/26/20       #4: Vises ...
Ian
Here's a quick video from yesterday's runs, I hope you can see it well enough
If you are seeing this message, your version of flash needs to be upgraded to view this video.
Click here to get the latest version of the Flash player.
6/26/20       #5: Vises ...
Hi Ian.
Can't see the video for some reason.
6/26/20       #6: Vises ...
Ian
Here's a picture, wasn't sure if I had one. Pretty sure they're Holzher WS- 6 if I remember right
6/26/20       #7: Vises ...
Thanks.
Just what I was looking for.
6/26/20       #8: Vises ...
Ian
What machine are you running?
6/26/20       #9: Vises ...
The little pod and rail is a Rover 20.
I also have 2 flat table Biesse Arrows and I'm setting one up with fixturing to do solid wood. It's kind of an odd machine because it has a tilting spindle with a C axis and a separate horizontal molding head that can hold a 150 mm wide cutter.
6/26/20       #10: Vises ...
I was going to say cocaine and hookers....
VISES, not vices....
6/27/20       #11: Vises ...
Ian
Arrow ATS?
http://https://www.youtube.com/watch?v=El2t3FD9bNU
6/27/20       #12: Vises ...
No.
Flat table like this one.
If I find an ATS at a decent price I'd likely get it. I tend to buy broken ones and repair them. Keeps the capital costs down.
https://www.youtube.com/watch?v=uUbcDZbinw8
