Barcode to access to worklist with Biesseworks
6/27/20
Derrek
Is anyone opening the worklist file on Biesse with a barcode scanner?
I run a Biesse Rover S. We output code to our machine through Cabinet Vision and open on the CNC as a worklist file. I have contacted Biesse and never get a straight answer on if it is possible to open the worklist via a barcode scan. Currently we name the file then open folder and scroll down till we find it. It can be time consuming as the file may have been generated weeks before its run and occasionally mistakes happen. Looking to simplify and mistake proof.
12/27/22       #2: Barcode to access to worklist with ...
ozan Member
did you figure out ? i need to scan the program name the pull out the program in folder since there over 100 programs. it only recognizes last or first 1 charter from the program name. For example if program name 1top and 12top it only understands 1.
12/27/22       #3: Barcode to access to worklist with ...
Derrek
Website: http://closetdr.com
My solution was to get rid of Biesse and buy an Anderson. File look up is so much easier
