Biesse CID programming
7/10/20
Good morning all.
I'm just playing with my new (to me) Biesse Rover 20. Great little machine. We've had it 2 months and can't imagine life without it.
It has an NC500 control.
I have been looking at programming options and it seems from the manual that it is possible to insert G code into a program.
I'm very comfortable with G code since I also have 2 Biesse Arrows which use it.
I'm hoping someone out there has experience doing this and can either walk me through it or send/post some sample code. I can handle the G code part but I'm unsure about the initial setup lines and the ending lines.
Also, do I start with a .pan or .iso program?
Any and all help and ideas appreciated.
7/12/20       #2: Biesse CID programming ...
Dan
It has been some time since I looked in depth to the Biesse Rover program language. The programming code, may look like g-code and is similar, but is not standard g-code. Also the Biesse code may be somewhat machine specific, in that what your machine needs may vary slightly from what a similar Biesse machine needs.
As for the start lines, the numbers after each line is a count of the number of characters to that section of the program. If I recall, the boring section is a seperate section from the routing section.
Also on our Biesse, the tools could be see up with a name. say a Compression Cutter 1/2" could be called "CC050" a down shear "DS050". This would be how the tool is called out both at the machine and the code. The control therefore was looking for a tool name, not a specific tool number like in G-Code.
Hope this helps.
7/14/20       #3: Biesse CID programming ...
A big thanks to Mark Tomlin of CNC Custom Services for getting me all squared away on this.
I'd recommend him to anyone who needs some Biesse help.
