Tapered ballnose bits
11/5/20
Travis Murray
We are trying to get into routing 3D objects on our CNC. See attached pics. Test part out of MDF. We are overlapping our 1/4" to 1/16" ballnose 90%. Will the "lines" be gone when we switch to hardwood? Use the 1/4" to 1/8"? Different bit?
Thanks.
11/5/20       #2: Tapered ballnose bits ...
BH Davis  Member
The larger the diameter of the bit the closer the bottom tip is to parallel to the CNC table. The more parallel to the table the actual cutting edge is the smoother the surface it will be that creates.
Switch to a 1/2" bit and do the test cut. If it is for a critical piece then do a 95% overlap. For the initial test though do about an 80% to see if that does the job. Going to the 1/2" dia. bit will I think give noticeable improvement.
11/5/20       #3: Tapered ballnose bits ...
You'll want in the range of a 10% stepover if you want clean. Super clean would be even a little less.
11/7/20       #4: Tapered ballnose bits ...
chris
I run a 7% stepover for fine detail. Your stepover can be adjusted to the amount of detail you have and of course run time.
    • Biesse America
    • SainSmart
      CNC and Engraving machines for Makers
    • Limtech Industries, Inc.
