Omnitech Selexx Mate
12/4/20
kitchen plus ltd Member
I have an Omnitech Selexx Mate CNC and I am having a problem getting the CNC to zero out on Z. It will zero out on X and Y no problem but when switch to X to zero out I get no response what so ever,no movement and no error. It seems to be dead. Has anyone had this problem before? Also looking for schematics for this machine if anyone has them.
12/7/20       #2: Omnitech Selexx Mate ...
Sam
Can you jog the machine in the Z axis?
I have a similar machine but mine has a home button that homes all 3 axis' at the same time.
If you cant jog in the Z then you might have a servo failure.
You can call Anderson America and the might be able to suggest some things
12/9/20       #3: Omnitech Selexx Mate ...
Is there an error on the drive?
12/11/20       #4: Omnitech Selexx Mate ...
Sam Jackson
Check your Z axis limit switches. When we shut the machine down for the night we manually job Z down so the switch is not in the "open" position. Dust can get in there and cause switch to fail. I've replaced mine twice. They are $40ish each. We have a Omnitech Selexx Pal. Good luck!
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
    • Biesse America
