Chipbreaker/finisher compression
12/15/20
David W Member
Is anyone using a chipbreaker/finisher compression bit on plywood? I just saw this type of bit on the True32 website. How is the edge quality? Can you run these at faster surface speeds than a traditional compression?
Maxlife Compression Spiral
12/16/20       #2: Chipbreaker/finisher compression ...
dan povinelli
Website: http://www.ctsaw.com
Hi David
Give them a call to confirm what they are selling because the picture shown doesn't correspond to the part # given.
60-172MW is a standard Onsrud 1/2" diameter x 1 5/8" cut length compression router bit, without chipbreakers.
But then down below on the site it lists this as 3/8" diameter, which isn't accurate for the part # listed.
To answer your question though, generally speaking you can run tools with chipbreakers faster than tools without. If you are looking to pick up speed also look to a 3 flute compression vs a 2 flute compression.
If you want to try a chipbreaker/finisher design tool in 3/4" plywood try a Onsrud 60-163C , this is 1/2" diameter x 7/8" cut length x 2 flute.
12/16/20       #3: Chipbreaker/finisher compression ...
We run 80% baltic birch.
1/2 compression spiral chipbreaker 19mm deep at 750 IPM all day long.
12/19/20       #4: Chipbreaker/finisher compression ...
We have run Vortex bits with and without chipbreakers and I do not see a significant difference.
I think the bits cost more and I believe they even cost more to sharpen.
