Anyone good with postprocessors?
12/16/20
Matthew Durand Member
Hi
Im trialing some software and the post processors is outputting fine apart from the z machining is minus into the board but i need it to be a positive number.
Is there something in the post processor i can change or would this be a default built into the software? which i cant find anywhere to change it in the software
12/16/20       #3: Anyone good with postprocessors? ...
BH Davis  Member
First I'll say that there should be a machine settings section in you CAM software where you can change settings. I'd think Z-axis settings would be editable there.
If not then in the few post processors I've worked with there are 3 or 4 files to be found in the file directory. One of them has been editable while the other 2 or 3 were in code and could not be opened.
You should look in your file structure on the PC and find the location of the post processors available. Then find yours and try to open each of the files. You might find what you need to change there.
12/17/20       #4: Anyone good with postprocessors? ...
Peter Matos
It would be helpful if you mentioned what software you are using and what kind of machine you are running it on. Most of the time Z height is something that is setup in the CAM and the Machine offsets. Good luck either way...
Pete
12/17/20       #5: Anyone good with postprocessors? ...
thankyou for the replies. All sorted now :-)
    • Machinery Associates
