CAD/CAM forWood Entry Doors
1/4/21
Dan Member
Hi,
We are looking to expand into CNC finally, I am looking to start off with machining slab doors for Hinges, mortise locks and typical machining on suit Entry doors. We are looking to machine all 5 sides, machine will have a horizontal spindle that rotates 360 Deg. as well as a vertical spindle. My question to all you is what software do you think would be suited for us? I have been quoted on Mastercam and like the looks of the software, price tag obviously fairly high. Fusion 360 or solid works going to be any cheaper? I know fusion works is cloud based which i don't care for but if it saves a ton on the upfront im not too worried. I am looking for a reliable program thats capable of what we need to do.
Thanks in advance for your input!
Bergen_Mortise.pdf
1/4/21       #2: CAD/CAM forWood Entry Doors ...
pat s gilbert
Look at Biesse for this
1/5/21       #3: CAD/CAM forWood Entry Doors ...
Peter Matos
Having run Mastercam and Solidworks for quite a few years in a CNC job shop environment I know that there is not much it cannot do. However it comes with a heavy price tag. Currently using Fusion360 in our commercial shop as well as in my CNC side business I am pretty pleased with it. It does everything I need it to do at a substantially lower price. Having said that using it for an angled head or aggregate head I have not done this just yet. I do know that it is possible using the idea that you can basically program on any surface of a part and run toolpath on it. I have a post from someone who has done it with Fusion360 and it apparently worked well for them understanding that you have to ensure that you travel in X or Y enough to clear the part before any Z movements can be done. I do not know if this can be done automatically when using it in this fashion. This of course has to be accounted for regardless of the software and to be honest I never did anything like that in Mastercam either so I cannot say how it works in that environment.
Fusion is very easy to use and has a lot of nice toolpath options albeit not as many as Mastercam. It is basically HSMworks under the covers if that means anything to you. The 3D toolpaths are more than adequate for everything I do and we have used them quite a lot. I am not sure there is anything in this realm other than Fusion360 that has its capabilities at this time for this price point.
Good luck with your business and let us know how you decide and how it goes.
Pete
1/5/21       #4: CAD/CAM forWood Entry Doors ...
Keith Member
Biesse Router and bSolid will do all that you require with machining on all 5 sides. Machining on the edges is as easy as machining on the face. Im not sure of the horizontal spindle that can rotate 360 but that is easily accomplished with an aggregate. I currently have a 5 axis Rover B but my previous machine was a Rover A with a C axis ring that we used with a 4 spindle aggregate to machine on the edges of parts. bSolid is Biesse's proprietary software that works great for us to do 3+2 axis work.
1/5/21       #5: CAD/CAM forWood Entry Doors ...
Dan Member
Thanks Keith, I won't be going with a Biesse machine so that software won't work. I have a line on a hybrid pod and rail/flat table with a horizontal head so I won't have to deal with aggregates.
Peter Matos, Fusion 360 is sure a huge savings compared to Mastercam thats for sure.
    • Limtech Industries, Inc.
