Need part for our CNC urgently
2/17/21
ExPat Member
We need an XCM2102L2 X-axis limit switch for our Morbidelli CNC router. We are down without it and every source we have tried doesn't have one - Monday or Tuesday would be the earliest possible. Any suggestions as to where we might look for a replacement - or if someone has one bone-yarded please reach out. I'm in a world of hurt here.
Thanks in advance.
2/17/21       #2: Need part for our CNC urgently ...
pat s gilbert
FWIW see if Morbidelli will put the part on an airplane.
Just about every passenger flight is carrying some freight along with the passengers and their baggage. ... Most of the freight is stored in special containers shaped to fit themselves to the inside of the cargo hold. Some of the freight is also put on pallets, and loose items may be placed in any open spaces that remain.
2/17/21       #3: Need part for our CNC urgently ...
Seems crazy for a limit switch.
Post a pic. Likely a OEM number for something off the shelf.
If you understand exactly what it does, you should be able to cobble something up using local parts.
2/17/21       #4: Need part for our CNC urgently ...
BH Davis  Member
Dropout x2. Exactly what I was thinking.
BH
2/17/21       #5: Need part for our CNC urgently ...
rich c
Get a machine electrician. He will quickly diagnose the type of switch, normally open/normally closed, and the capacity. Then from someplace like McMaster Carr or Graingers will get you going in a few hours.
2/18/21       #6: Need part for our CNC urgently ...
ExPat Member
We found something we can make work, thanks for the help guys.
    • Limtech Industries, Inc.
