Biesse general questions
6/16/21
Jason
Hey guys, I am considering a Biesse Rover B with a flat table. It is a 2004 machine looks to be in good condition. I am not a newbie in the cnc wood world, but Biesse has not crossed my path yet. I have a Komo right now, just want to get a 2nd machine for redundancy. At my old job we had a Busellato, a Komo and a pair of CR Onsruds and a Giben. I programmed with mastercam and also used Busellatos' software and a converter to go from autocad to the genesis control software.
Anyway, my questions are mainly around the control and software. First, what operating system would this machine have? Would it be on XP? On the machine control, is there a parametric option? What would I have to do to get a dxf to code I can run on it? If I get one, I need to be able to do signage, millwork, weird one off stuff, etc as well as nesting cab parts. Can any of these be done with the control? I am assuming I'd use a CAM program and appropriate post, but just don't know for sure on these. I'd rather get an idea from some users before I get on any mailing lists in case I decide I am not going that direction.
Also, are they reliable (control/software and mechanically) assuming not abused?
Thanks for any help,
Jason
6/16/21       #2: Biesse general questions ...
Kirk M. Walby
We bought a Rover B flat table in 2007 brand new and it's still going strong. Very low incidence of repairs or glitches. Yes, it is most likely running on XP, ours is. WE use autocad and import the dxf's into the Biesse
software. It is very user friendly software at the machine but obviously not as powerful as autocad. We've got 4 CNC machines, 2 of them Biesse and this Rover has been by far the least troublesome, most dependable workhorse that you can imagine.
6/16/21       #3: Biesse general questions ...
Jason
Kirk, thanks for the reply. So, the control can directly import a dxf? That would be nice.
Have you used any other software with it?
6/16/21       #4: Biesse general questions ...
Kirk M. Walby
We have several "seats" in the office with Biesse software and a dongle. We do all the importing there and modify the cut direction, changing of whether it's inside or outside the line cutting etc. Then our operator pulls up the program from the network and away he goes. I would imagine you could do the dxf import right at the machine through a flash drive or network just as well. It's the same software. Not sure how close you are to Metro Detroit Michigan but you're welcome to come look at ours for a demo if you wish. We haven't used any other software with it.
6/17/21       #5: Biesse general questions ...
2004 is pretty old for a Biesse. If the O.S. can't be upgraded, I would shy away from it. If the machine was a Komo with Fanuc control, I'd probably be in, but I would be afraid to jump on any of the Italian machines.
6/17/21       #6: Biesse general questions ...
cabinetmaker
We just loaded out a Rover 30 that we have had for 8 years. Was down a total of 4 days from the time we bought it, and ran several million dollars worth of panels through it. We ran the dog piss out out of it.
We had 1 software issue once that was a plc hick up and a tech from Canada dialed in and had us running that afternoon
Very stable. Very reliable. Run it from the office to get the. Most out of it
6/23/21       #7: Biesse general questions ...
Jason
Update, I decided to pass on it only because the seller doesn't have the dongle needed to run it. He bought it at auction and didn't get it with the machine.
I just don't need another machine bad enough to get it making parts at my place. I wish he did as I think it would be fine from what I saw.
Thanks for the info.
6/23/21       #8: Biesse general questions ...
yaakov Member
jason
biesse work no need any dungle ,what you post its far from true
the dungle only for extra: pocket ,simulation,fictive faces
and nesting cnc not need any of this options
    • Machinery Associates
