B Solid
6/25/21
Kristin L La Scola
Can you tell me how to run a BSolid program through the post processor. The new guy I have doing design and programming has programmed for metal working shops on HAAS machines, but when he gets the program finished on BSolid and goes to run it through the post processor. He gets a red processing result that says the toolpath Pocketing/Roughing has a CAM error 9 and that the tool minimum working SPEED for mach.op. (10800.0000) is not between Min (18000.0000) - Max (18000.0000) Limits for tools. I do know that the guy we previously had here designed all the tools and locked the values. I also think that it could be a simple work around. Because we have ran programs from BSolid on out Biesse Rover A before.
6/28/21       #4: B Solid ...
Garrett Arnold
Website: http://kristin@centrocabinetry.com
I figured out the tool issue Friday afternoon. The only other issue I am having now, is that when I run the program through the post processor, it is saving the file as an ISO file. I need the file to be saved as a CIX file, and when I go to the properties of the file and change it, the format of the file is all jacked up. I also tried to just export the program on BSolid to try to get my Biesse Rover A to read it, but I must be missing something. Because the machine isn't even trying to read the program, it just sits stagnant, like the code is wrong. I could use some help, the machines that I used to run and program, I could adjust the G and M codes to make it work. This Macro Format of codes is a whole new world and I can't seem to get the format right.
6/30/21       #5: B Solid ...
Dylan Bayliss  Member
Website: http://www.machineconsult.com
Garret, what post processor, or ie design software are you using, the machine will run the Iso from the worklist if correctly posted out. Some design softwares/post will export .cix and some .iso. The advantage of the .cix is that you can open it and modify the parameters, program speeds, leads, and geometry at the machine level
I would encourage you to contact service@biesseamerica.com with your serial number and work on taking an online course in Bsolid or to evaluate your .iso.
regards
db
    • Better Vacuum Cups, Inc.
    • Limtech Industries, Inc.
