best bit for 1/2" baltic birch
7/15/21
Jonathan Mahnken
looking for opinions as to which bits and bit types perform best in BB. I will also be doing shallow rabbets and dados in said material without a tool change.
7/15/21       #2: best bit for 1/2" baltic birch ...
If the dados are over 3/16" depth from the surface, I would recommend a mortise compression tool from Vortex. 3/8" diameter is #3285. That tool is my most versatile in my inventory. Use it on everything from melamine to plywood. You can achieve good feed speeds on most materials and they last a good long time before service.
7/16/21       #3: best bit for 1/2" baltic birch ...
Use a chip breaker if you're going to lots of it.
7/17/21       #4: best bit for 1/2" baltic birch ...
Jonathan Mahnken
Thanks. Dropout, what kind of edge are you getting with the chip breaker? Also, shooting for a 1/8” dado/rabbet in this material
7/17/21       #5: best bit for 1/2" baltic birch ...
Great for a while. We run them until they break :)
I always use a down spiral for a dado, especially on ply. You won' t be able to find a compression spiral that will do a 1/8 dado.
If you cannot do a tool change, look for a slow spiral downshear. That will slow your feedrate down though.
We're cutting 12mm BB at about 900 IPM.
7/19/21       #6: best bit for 1/2" baltic birch ...
Bill Member
Run them until they break? Ever consider sharpening them?
7/19/21       #7: best bit for 1/2" baltic birch ...
Some day.
My current post doesn't read offsets from the control so it's not worth the effort.
Once I get Alphacam posted to all my machines we will do so.
7/19/21       #8: best bit for 1/2" baltic birch ...
Dropout,
That doesn't make sense. The post doesn't read offsets, it just tell the control to use them. Every control I've used since the 1980's can read diameter or radius offsets. The control does the work, not the programmer. All the post does is output code.G41/G42 typically turns on the offset coupled with a value from the registry. What are you using for outputting code? I'm curious now.
7/20/21       #9: best bit for 1/2" baltic birch ...
Christian L.  Member
This bit coated does a great job in plywood, just contact us to set up chip loads for your application.
CL Chipbreaker Compression 3flute Router Bit
7/22/21       #10: best bit for 1/2" baltic birch ...
raphael
Website: https://www.frontiercabinets.com/
We use Vortex's 3289 three flute compression bit.
Vortex 3 Flute Compression Bit
    • Biesse America
    • SainSmart
      CNC and Engraving machines for Makers
    • Limtech Industries, Inc.
