Anyone running a flextrim sanding cup?
8/5/21
Mark B
Have a potential large run project that will require decking off sheets full of inlays before they will be cut into individual parts and even though its not an RO option Im looking into anything that will do some course initial sanding and take out as much of the tool marks as possible before they come off the machine.
Im a little concerned only having a 10hp spindle and not being able to get the RPM's below 6K and of course the hit on the power curve but had assumed sanding would be pretty light load.
Have a voicemail in to flextrim but wondered if anyone had any first hand experience. Thanks.
8/6/21       #2: Anyone running a flextrim sanding c ...
Mark B
Scrap that. Never could find it on their site but max RPM is 1000. Back to the drawing board.
8/8/21       #3: Anyone running a flextrim sanding c ...
Mark
Like this? I haven't used it, but seems like it may fit the bill. Provided there is enough to justify the cost.
8/8/21       #4: Anyone running a flextrim sanding c ...
Mark
Sorry, missing a link.
Not sure if this is fitting for you, but it looks like it reduces speed.
https://www.youtube.com/watch?v=X_D8Qf6n-vE
8/9/21       #5: Anyone running a flextrim sanding c ...
Mark B
Well, the throughput required for that setup would be far and away more than what I am referencing hence the flextrim.
There was another RO sanding head option that was floating around several years ago that I dont think ever made it to production.
We have a different solution for the CNC in the works at the moment. Thanks a bunch
9/17/21       #6: Anyone running a flextrim sanding c ...
Jason Scott
I have researched the cup brushes a lot. They won't really remove mill marks. Are you looking for the edge of the material or the face to be sanded?
If you are doing edges than these are really nice for that application.
https://www.peaktoolworks.com/product/supersand/
9/17/21       #7: Anyone running a flextrim sanding c ...
Mark B
We were (are) actually trying to automate some fine finish sanding on some 3form panels (face sanding). These parts would all be decked off on the cnc with a pretty clean surface and the bulk of the face of the sheet would be un-touched just flattening some in-lay and were then hoping for a sanding option through a couple grits to remove the tool marks (very light).
9/17/21       #8: Anyone running a flextrim sanding c ...
Jason Scott
From what I have seen the cup brushes will not remove milling marks or cross grain sanding marks. They will soften edges and "defuzz/denib" parts but they aren't designed to remove material.
Maybe they could make a Super Sand head that acted like a cup brush you would get circular scratches but they would be better than tool marks. The built in cushion would protect your parts and your spindle from damage as long as the programming wasn't wrong.
I would think that would be the option I would explore.
Dylan at CNC-TOOL.COM would be a good contact to ask. He really knows his stuff and his router bits are great quality and really great prices.
