FIRST CNC PURCHASE
12/1/21
RODNEY BLACKERBY Member
we are looking to at a shopsabre cnc the IS model 5x10 anyone have any opions on this machine wold be greatly appreciated we use cabinetvison software we currently have 4 employees more needed but finding skilled help is near impossible, we do residential and some commerical.
12/1/21       #2: FIRST CNC PURCHASE ...
Mark B
We have the pro model down from that machine and know another shop with the 5x10 IS, phenolic, 10pos ATC, and zero complaints. Zero from me on the PRO but we too are small shop. I looked hard at the IS but no complaints with the PRO and service after the sale from ShopSabre, from me, has been nothing but phenomenal not that Ive needed much other than operator error. Machine has run flawlessly other than some power issues on our end initially (make your you check your incoming voltage incase you need to buck/boost). We had to buck a pretty heavy over-voltage from the utility but not a major issue.
Great machine for us. Heavy, rock solid, robust. But we are not running 40 sheets day in and day out. Very varied work flow.
12/2/21       #3: FIRST CNC PURCHASE ...
james e mcgrew  Member
Always go see shops, meet owners maybe even a couple of different machines, you will need friends and this is always a good idea.
12/5/21       #4: FIRST CNC PURCHASE ...
James nailed it. See different machines work. Ask about the good and the bad.
Get the biggest drill block you can get.
12/10/21       #5: FIRST CNC PURCHASE ...
Thomas Hitefield
Rodney, we own a Shop Sabre pro408. Tech support is great. Machines are well built. USA made and a forum that will help you out on weekends and holidays. Great honest company. Brandon will not steer you wrong.
1/9/22       #6: FIRST CNC PURCHASE ...
Beta CNC Member
Website: https://forsuncnc.com
Unfortunately, I have not used this machine, but I have purchased a 5x10 CNC router from FORSUN CNC in China, they have a lot of instructional videos about the CNC router machines, I think you can refer to it.
    • Template Services
    • Biesse America
