Weeke homag linear guide question
12/13/21
Anthonyg
Hello all hope your having a good day
I own a weeke homag and i have a questiion about the linear guide greasing
When i push the grease inside the nipple of the linear guide grease will come out of the side of the linear guide is that normal?
12/14/21       #2: Weeke homag linear guide question ...
Acctek  Member
Blocking the mounting holes of the guide rail with the protective belt plate can not only improve the sealing effect, but also be beautiful and practical, so that the top surface of the guide rail is smooth and flat.
12/14/21       #3: Weeke homag linear guide question ...
Yes, that is normal. The bearing design is open, so grease will come out as you pump it into the fitting. Just move the machine around and wipe down the rails so you don't get grease on your parts.
12/16/21       #4: Weeke homag linear guide question ...
What Mike said.
Wipe up all the excess, up. It sucks when you get grease on the sheet when a wad breaks free and ruins your life
